cleaning air fins
Topic Started: Jun 12 2017, 02:21 AM (326 Views)
Bal
Hi there, i am trying to clean the air fins from the corrosion of the past years. i have tried silicone brushes, nylon brushes but they did nothing major. i tried with my dremel with abrasive wheel mounted but it wont fit between the air fins. i haven't tried wire brushes as i believe that it will scratch badly the engine. any ideas on how to remove the corrosion welcome..
Jed61
Hi ive just painted my whole engine on my 87 gt750 :256 to clean the corrosion between the fins I used wire wool and a thin stick loads of patientce needed but done the job
JesterYHZ
:445 The other option is to take the head and cylinders off and put them in a bead-blaster. See pics :444
Attached to this post:
Attachments: ZN2.jpg (140.06 KB)
Attachments: ZN22.jpg (112.72 KB)
Bal
Thanks for the tips. I have the wool wire, I bought the ultra fine one and I will use knitting needles to mount the wool wire on. I will start tomorrow and tell you how it is going. Thanks again.if this does not work, then I will think the other option.
Daturat100r
I made me own soda blaster and blasted them clean
« Previous Topic · Kawasaki Classics · Next Topic »
Copyright © 1999-2017 All rights reserved www.kawasakiownersclub.com
