1980 Z650 Air Box Fitment; Z650Air Box Fitment
Topic Started: Jun 27 2018, 07:10 PM (176 Views)
mutleyz
Hi All,
:991
I am slowly rebuilding my 1980 Z650
Engine back in frame with inlet trumpets fitted, I recall the air box must go in before the carbs but for the live of me I can not get the air box in??!! :256 :lkl
When trying to put the air box in it hits the frame and or the camchain tensioner :256 :lkl
Help
David1963
It’s a long time since I’ve done this with a z650 but IIRC, you need to either put the air box in before the engine or remove the front engine mounts and the top rear one to let the engine tip forward in the frame, thus giving you a little more room.
If that doesn’t work then you’ll need to either remove the engine or at least the cam chain tensioner.
mutleyz
Sugar, I had another look this evening and came to the same answer :256 :256
I will get at it over the weekend and let you know how I get on
mutleyz
Hi All,
Update, air box in !!
Leave lower front engine mounting bolt in situ, remove all the others tilt engine forwards, fit air box, position as far back as possible then fitted carbs.
Refit engine mounting bolts, then carbs then air box
Good after noon work in the SUN
« Previous Topic · Kawasaki Classics · Next Topic »
