Newbie Dustin; 86 ninja 600 exhaust leaks
Topic Started: Nov 8 2006, 07:33 PM (544 Views)
silentsineater
Hi there I just started fixing up my 86 ninja 600 with a vance and hines exhaust and a Dyno jet kit stage 1. I was wondering if anyone has a good tech for checking for exhaust leaks? I am glad there is a form for Kawasaki riders
:441
dogdragon
I usualy wet my fingers and runs then about 1" (2.4cm) from the connections on the pipes when the engine is running, best done when the engine is cold, (try not to get burned), it helps you feel the air pressure coming from the holes/leaks if there any).
smear a bit of washing liquid (or spit will do) over and areas might be suspect to make sure.
Hope that helps.
Si
2 users reading this topic (2 Guests and 0 Anonymous)
