fuel valve; operation of primer setting
Topic Started: Apr 19 2007, 11:23 PM (466 Views)
ruben
I have a 1979 KZ650 that has a "primer" position on the fuel shut off valve..can someone tell me what it does and how and when to use this position..thank you
dogdragon
The prime setting means that the petrol tap works as a gravety fed fuel system. avoiding the diaphragm, letting fuel run freeley through the pipes from the tank to the carb. If you want to learn more about the diaphragm tap on Kawasakis, I have put a page up on my web site showing a stripped petrol tap from my RX1000 (ZX10a)
Check:
http://www.dogdragons.com/dogdragons/maint...hragm_taps.html
for more information
Si
Dougw650
Dougw650
THE PRIME POSITION IS AS DOGDRAGON SAYS,BYPASSES THE DIAPHRAGM TO FILL THE CARBS.
YOU SHOULD ONLY NEED TO USE IT IF THE BIKES BEEN STOOD A WHILE OR THE CARBS HAVE BEEN STRIPPED & CLEANED.ON NO ACCOUNT LEAVE THE TAP IN THIS POSITION,AS PETROL WILL EVENTUALLY RUN INTO THE CYLINDERS AND WILL WASH ANY LUBRICANT OFF THE BORES.
