What is rejetting?; Exhaust´s
Topic Started: Sep 2 2008, 05:37 PM (751 Views)
Frank
Iv just put a yushumura rs3 exhaust on my 51 reg zx6r and someone said something about it may need rejetting what is this and do i need to do it, thanks for your help
higgsy
higgsy
First off - I'm not a motorcycle mechanic.
But rejetting refers to the jets or "orifices" that the fuel passes through inside the carburetor.
I Wouldn't worry about rejetting the carb until you've ridden it for a while. Changing exhaust doesn't necessarily necessitate jet change. However, changing the intake is more likely to require it than chaning the exhaust. If you hear the engine "pinging", a noise like shaking marbles inside of a tin can, that as well as backfiring is a sign of a too lean mixture and you need bigger main jets. If the bike "blubbers", doesn't accellerate as crisply as before and soots up the exhaust, the main jet is too large and a smaller one needs to be installed. Hope this helps.
Frank
Thanks that is a help, when i start the bike in the morning it always backfires but never used to and it does ping and also smells very rich so do you suggest i look into it futher and will it harm the bike if i dont? thanks for your help
higgsy
higgsy
As a precaution i would get it checked a.s.a.p, If i remember correctly running rich makes things a bit hot?. I would personally take it to a garage or reputable mechanic, I would imagine if bigger jets are needed then you'll probably need the carbs balancing to. Good luck with it.
Frank
Better to be safe than sorry, Thanks again for your help
ZetaBoards - Free Forum Hosting
ZetaBoards gives you all the tools to create a successful discussion community.
Learn More · Register for Free
