tire pressure recommendations
Topic Started: Feb 17 2009, 02:13 AM (830 Views)
ninjaryder
I'm riding an 02' 9R for track days, has anybody got some tire pressure recommendations for the Pilot 2CT's?
Kawasaki Merc
Hi there, this is a quote from a question and answer session by Bryn Phillips, formerly the Tyre Technical Specialist for Bridgestone UK. I know your question was specific to Michelin tyres but I believe they have the same rationale.
"Q. What would you recommend the best tyre pressures to be for front and back tyres with just 1 rider?
A. As for pressures, you should use those recommended by the tyre's manufacturer. They may be higher than those recommended by the bike manufacturer, but the bike manufacturer has only tested the bike with the tyres that come fitted when new and will not be familiar with the performance and characteristics of other tyres. The pressures recommended by the tyre manufacturers are also suitable for solo a 2-up use. Higher tyre pressures also lead to increased high-speed stability and to slightly cooler operating temperatures and hence longer tyre life. These days, for street riding, it's not necessary to reduce pressures to "solo" settings in order to improve grip because, as I've explained, unlike tyres of 10 years ago they do not suffer from a lack of grip."
Hope this helps and if you want to read the full transcript of his (Bryn Phillips) advice, then check out this link.
http://shipponsmcc.21.forumer.com/viewtopic.php?t=73
:kawas :kawa
Delooney
I've been runing Bridgestones BT014's on my 06' ZX636.
On track days I've dropped from 36/42 to 32/36.
Not really noticed much improvement at the rear but the front is now using a bigger foot print than before.
If that helps...
Delooney
GavNinja12
you will have to try some and get a feel. When I raced a ZXR400 I ran 28 front and 29 rear on Metzeler Rennsports.
On the road I have Brid-016 on my ZX and run 36 in both but i do so much motorway mileage. This helps with longevity, I drop down to 30psi for Snetterton trackdays.
hope that helps
ninjaryder
Hey guys, thanks for your input....................
quick question. when riding alone and i feel a bit racy, letting tyres down by 5psi is great but what about when carryin my *itch ???
