very temperamental eliminator; Please help
Topic Started: Jun 10 2009, 05:33 PM (699 Views)
ellyanne
Hi there. I have a Kawasaki Eliminator 250, 1991. Is very sluggish and jerky especially in lower gears. In first gear, betweem 3000 and 4000 RPM is a struggle to get her going, in second is between 5000 and 6000 RPM. I have cleaned the carbs more times than I can remember, cleaned the sparkplugs too, but it does not seem to make any difference. She's very thirsty too, I hardly manage 100 miles on a tank, and I think that's pretty bad. I had another EL250 before and I used to get 130miles out of a tank before going into reserve. I learned recently that the engines they put in the EL's are the same they put in Ninjas 250 and I tried to be a bit more aggresive in my riding but that didn't change anything. Can anyone give me any ideas what could the cause be?
:444 :444 :444 :444 :444 :444 :444 :444 :444 :444 :444 :444 :444 :444 :444
MasonER5
Just a thought m8 but try adjusting your fuel/air screw, if the screw is too far out it will be using up too much fuel and making your bike run rich, which would also eeffect your bikes performance.
:fdq
owdbiker
Don't know if you've solved your problem.Check your plugs.If they are black you are running rich.I have a Ninja 250R and can get between 300 to 460 miles to a tank.The capacity of which is 3.7 gallons.
