Advice!!; Chain and sprockets
Topic Started: Oct 5 2009, 10:42 PM (572 Views)
blacktooth
Hello all,
Im after some advice on which brand and type of chain and sprockets to put on my zx6r j2. Dont want to change the ratio or anything, just dont understand the type's!
Thanks for any response!
darkember
If you don't want to change the ratios then you will need to count the teeth on both sprockets in order to get a match.
order the standard stuff from a dealer then you know its right and decent quality
crazyoldcat
What the year because over the year they change the pitch they like to keep it simple :tthu
1995 - 2002 525 x 108 links
2002 - 2004 520 x 118
2005 - 2006 512 x 110
2007 - 2008 520 x 112
you can order over the Internet if your sure you have the correct size
then there's the choice of o ring or x ring chain heavy duty etc
if it was my bike i go for the x ring chain prices range from £90- £135 depends were you go as for the make it should have the makers name stamped on the chain every one has the favorite brand the choice is yours
:644
