05' Z750 bar end removal; Getin' the bar ends off.
Topic Started: Apr 1 2010, 06:51 PM (1,756 Views)
jbdbsb
Hey people.
How do I get the bars ends of my 05' Z750! It's so frickin tight. It's just a philips head bolt/screw right? I even tried using an impact driver. Am I missing something?
Jeff
Little John
I had the same problem, so drilled the head off removed the bar end, and put mole grips on the stud with a dose of WD40.
i couldnt either , resorted to the electric drill in the end
darkember
I have used an impact driver works a treat
bongorilla
try putting a screwdriver bit in a ratchet handle from a socket set . you can push on the head to prevent slippage and also allow for good leverage . keep trying , its quite hard but its just the locktite thats used that makes it difficult. they will never go in that firm again .
Edited by bongorilla, Jul 5 2010, 10:02 PM.
McVicar
Little John
Apr 1 2010, 08:35 PM
thats what I did after trying every
thing else including an impact driver.
bongorilla
i got mine out no problem but the rachet handle suggestion is a good one
