oilchange; oil has gone creamy
Topic Started: Feb 20 2011, 11:37 AM (742 Views)
MAD MAG
hi can anyone help ive just changed the oil + filter on my zxr 636 b1h and when i have checked the oil level its gone a creamy yellow colour, any ideas ? thanks rob. :unsure:
janandrog
janandrog
That sounds like oil water emulsification. Usually caused by coolant entering the sump or lubrication system. can be extreem condensation. check you coolant system, are you losing water?
MAD MAG
hi thanks for your help im not using any water so it might be condensation ,ive not had the bike long and its my first oil change so ive been told it might be caused by semi synthetic oil mixing with full synthetic oil , might have to flush the oil and change oil and filter again cheers rob :unsure:
janandrog
janandrog
ok, as you say. good luck hope the oil change and correct oil will do the trick. make sure your crankcase breather is clear.
cheers rog.
MAD MAG
thanks for your help im dropping oil at weekend al keep you posted cheers rob
