Removing dynojet kit from ZXR750H1
Topic Started: Sep 5 2011, 08:58 AM (444 Views)
chrisdhall
I'm trying to remove a Dynojet kit from a ZXR750H1 and have come up against a problem. The installation of the kit requires the drilling out of the small hole in the throttle slides. Unfortunately I don't have any information on the original size of that hole.
Does anyone have a standard ZXR750H1 that could measure the diameter of that hole? (Note, it is not the hole for the needle).
Chris
Styles Scratcher
Well id question removing the Dynojet to start with unless it was running like a proper dog and even then id just change the settings of the dynojet.
One option would be to look at/buy a Hynes manual.
Buy a second hand / breakers carb set.
donjenjes
Hi Chris,
I am in Sutton, Surrey, is that anywhere near you?
Regards
Kevin
:kawa
