99 zx6r K&N air filter; Will putting a k&n on my 99 zx6r help performance?
Topic Started: Sep 13 2011, 07:32 PM (676 Views)
d1andonlyantman
Hi. I was just wondering if its worth buying a k&n air filter for my 99 zx6r and if its hard to put in? Ive had it dyno jetted, got a decent can and am waiting for delivery of my ignition advancer so will it help performance even more if i do fit a k&n?
Nothing that you would notice.
K&N filters are in general made of quality materials which is reflected on the price, and of course they last very long. They do allow more air, but they do so by simply filtering LESS. It simply has bigger openings than stock.
d1andonlyantman
oh ok, thanks. its just because people talk about k&n's like they're the best air filters. from what you've said they're actually the worst air FILTERS
deadwood
Hi D1.
For my two p worth K&N filters are the dogs danglies....
For effective engine tuning the secret is to get more out of your existing engine without going overboard.....for an engine to work more efficently and give out more power you need to get as much air in as possible..thats why tuned car engines have turbos...to get as much power out of a small a motor as possible.
So if you put a nice end can on your kwaker the exhaust gases can get out quicker..trouble with that if you dont do anything at the other engine you only gain a little more power..so what you do is try and get the air in as fast as the exhaust gases come out..so you do the sensible thing..you fit a K&N filter...they filter just as effectivley as a normal filter but they do it in a different way....so yes you should fit a K&N filter to get the most out of your new shiney end can...just make sure you get a cleaning kit for your filter and clean it frequently as per the intructions...
:693
Crack on mate...
Regards Deadwood
d1andonlyantman
Thanks Deadwood. No disrespect to Hugo but thats kinda what i thought. Didnt think K&N got their name by making poor filters to be honest.
tstain71
get the "oops" dyno jetted and set up properly or risk exhaust valves cooking!
d1andonlyantman
tstain71
Sep 14 2011, 08:16 PM
it was already jetted when i got it almost a year ago and ive thrashed the nuts out of it and its still fine so im not worried, but once i fit the advancer and K&N next week im going to get it all set up properly again anyway to get it running as sweet as possible :-)
Edited by d1andonlyantman, Sep 14 2011, 08:24 PM.
d1andonlyantman
ah, i see what ur saying. yeah, am gonna get it all set up properly. was told it might run lean mid range after the advancer so am gonna get the carbs and everything all tweeked to get it spot on
