| Low speed wobble; how to fix | |
| Tweet Topic Started: Sep 16 2011, 04:54 PM (819 Views) | |
| lmddmc | Sep 16 2011, 04:54 PM Post #1 |
Hi I have a 1992 Kawasaki 1200 voyager and I have a low speed wobble in front end when I am going about 20 mph and move the steering back and forth the steering starts wobbling and keeps doing it till I slow down and then its ok . I have cked the triple clamp and bearing s and they have the right preload any thoughts Mark
Edited by lmddmc, Sep 16 2011, 05:58 PM.
| Mike Folks | Sep 16 2011, 05:15 PM Post #2 |
Mike Folks
I copied this from a post from Jeff Saunders(owner of Z1 enterprises) Motorcycle Wobble Causes There's a LONG list of potential area that can cause this. These are not in any particular order Wheel bearings Steering bearings - repack grease, check tightness Swing arm bushings/sleeves/bearings - replace is worn, repack grease Fork springs aging - check spring length Unequal fork oil - if seals leak, then your damping can be ineffective Rear shocks aging, damper leaks - if you have oil leaking from the seals, the damping is toast. Worn Tires/Mismatched tires/tire pressures/wrong size tires Wheel alignment - don't trust the chain adjusters - I visually align the wheels. Bent rims/broken spokes - get the wheels off the ground and spin them - check for runout / damage Front disc warped - check for runout Steering & swing arm bearings are very common problems, but so are tire issues (pressure/mismatch) and wheel alignment. |
