zx6r lumpy/rough running at low rpm
Topic Started: Oct 16 2011, 08:38 AM (2,078 Views)
ninjavanish
I have just brought my first ninja (99) and although it runs great at faster speeds when your running round town trying to hold speeds of say 30/40mph it seems to run abit rough maybe jumpy. From what i can gather the bike is standard except for a scorpion end can and the carbs were recently balanced. Any ideas?
rjk1188
turn you pilot screw's out 1/4 turn try it see if better, may need 1/2 turn out
ninjavanish
rjk1188
Oct 16 2011, 07:21 PM
Thanks for the reply. Im not very good with bike engines. whereabouts are the pilot screws and how do i get to them. Thanks
Not knowing your bike mate but most are on top front. One on each carb.
colombo2099
Man you need to learn your bike! If your carb'd then it should be underside of the carbs, i think you have CV carbs. theres going to be a plug covering that mixture needle though....
http://myural.com/keihin_32cvk_disassembly.htm
different bike but the carbs should be similar, good way to get accustomed to your parts.
