| GT550 Clutch Problem; Loose clutch arm? | |
| Tweet Topic Started: Feb 27 2014, 01:56 AM (637 Views) | |
| howleii | Feb 27 2014, 01:56 AM Post #1 |
Hi, My clutch cable snapped and I replaced it but the arm that connects the cable to the clutch internals seems very loose, and it doesnt spring at all, it doesnt catch onto anything and can swing full 360 without catching onto to anything inside the box. It worked fine up till the cable snapping. Weather is getting better and im dying to ride!!! Please, some or any help is greatly appreciated! Thanks!
| 67fire | Feb 27 2014, 03:47 PM Post #2 |
Adjust the arm (remove and rotate on the splines) until it JUST meets the end of the new cable (both holes line up) and then adjust from there. The arm should be just slightly pressing against the push rod at this point. Eric |
| steve w | Feb 27 2014, 05:37 PM Post #3 |
ya shouldnt be able to pull that arm out ..you need to remove the casing looks like somethings snapped off
| howleii | Feb 27 2014, 11:22 PM Post #4 |
thanks for the replies i took off the casing and had a look, here are the pics. i didnt find anything that looked like it came off the end of the pin, so not sure why it isnt catching the clutch arm. has anyone ever changed the clutch on a gt550 before? need help thanks |
| steve w | Feb 28 2014, 11:26 AM Post #5 |
looks like the arm on ures is worn out .. |
| howleii | Feb 28 2014, 12:07 PM Post #6 |
hmm could be, i hope not tho.. I'll have a look now and see if there are signs of wear. is it a part that wears easily? |
| howleii | Mar 2 2014, 10:35 PM Post #7 |
ya i am i bit of a dope.. all is well with the gt! turned out that the shaft, connecting to the clutch pressure plate, was in too far and not catching the pin properly. i should be on the road this week! sweeet... cheers for the help lads! |
12:33 AM Jul 11
