tapping from front brakes; tapping from front brakes
Topic Started: Apr 1 2014, 06:19 PM (299 Views)
ngudger2021
hi guys,
im getting a tapping from my front brakes. its getting louder as time goes on but i cant seem to trace it to fix it.
the brakes work fine. also when i apply a bit of pressure to the front brakes the tapping goes.
pads look fine,
disks look fine
any ideas.
Cheers
Nick
zxr2
have you taken the brake apart to have a proper look ? check all bolts are tight , take the pads out and have a decent look at them, it may not be your brakes it could be your suspension best to check the front forks for damage
keep us updated bud
oh and what bike its
regards harry
kwakjack
apprentice mechanic
hi nick, I get a similar thing at low speeds, after thorough investigation I have put it down to a slight warp in the disc(not enough to feel while braking) and a bit of wear on the pad retaining pins, yet another thing I will get round to one day :)
ngudger2021
ZXR2
it is a zx9r c1. it's not the suspension as it does it when the weel is off the floor.
i have had the brakes apart and they do look ok, However i am doing it again this weekend to double check "weather permiting"
kwakjack
this sounds more possible. i will be going in again weekend to have a look.
Cheers for the advice guys :-)
i will get back to you when im done.
Cheers
Grouty
I had the same thing a while ago with my SV650.
After checking I found the mountings between the bell and the disc were worn and allowing it to chatter when not under load.
It did not affect riding other than being annoying. It went away as soon as the brake was applied. I renewed the discs and it all went away.
To check this just try and move the disc back and forth. If it moves you will hear the dry chatter from the "bobbins" that locate the disc to the bell (or hub).
